Author Topic: did I disturb the injection pump timing while removing tach drive?  (Read 2366 times)
erickmarciano
  • Canada, Quebec, montreal
Hi guys could I have disturbed the injection pump timing while removing the tach drive?
It was really hard to remove and as I was trying the chain moved < head is off> .
by the chain moving could that disturb Injection timing? I am able to move the distributor by turning the gear one way the other way It does not move , I suspect it moves with the crank
« Last Edit: March 29, 2016, 02:32:16 by erickmarciano »
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Should not have moved.
The only way the intermediate shaft to crankshaft relation would have moved is if the chain jumped a tooth on the intermediate shaft. This is not possible unless you removed the bolt/pin on the engine block. This bolt/pin is on the front, and side of the block at the 3 o-clock position in relation to the distributer drive housing. It also secures the power steering pump bracket.  It keeps the chain from leaving the intermediate shaft sprocket.
