Author Topic: Distributor shims and fiber washer??  (Read 5085 times)
erickmarciano
  • Canada, Quebec, montreal
« on: April 03, 2016, 20:29:47 »
Hi guys
Taking apart my distributor there is a fiber washer that fell apart. Can I replace it with a regular one?
Where should I add a shim to reduce up down play ? Where the red plyers are or my blue glove?
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: Distributor shims and fiber washer??
« Reply #1 on: April 04, 2016, 04:14:49 »
You need to retain the fiber washer as it absorbs and holds on to oil. Get ahold of Glen Beck. He should be able to help you out with a new washer and other needed parts.
http://www.glenn-ring.com/bosch/
« Reply #2 on: April 04, 2016, 18:49:12 »
There are actually two washers that go on the main shaft. One goes at the top below the two shims and the other goes above all of the shims at the drive collar. Shims come in several different thicknesses and are used to remove any end play. All of these parts, and more, come in a rebuild kit which is now over $150.00 USD.
  I used to do a lot of distributor rebuilds but the cost of the rebuild kits and everyone going to electronic ignition kind of made it pointless......
erickmarciano
« Reply #3 on: April 04, 2016, 19:51:19 »
My bottom fiber washer was missing and has very little oil in it. Can I just replace it with a regular distributor washer?
« Last Edit: April 05, 2016, 03:03:46 by erickmarciano »
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #4 on: April 05, 2016, 03:18:41 »
I think so, as long as you have some the right thickness.
