Author Topic: Heater air distributor  (Read 3076 times)
Peder
  • Norway, Oslo, Oslo
« on: April 07, 2016, 09:19:29 »
I have bought a used air distributor for the heater. There are some electrical cores at the right hand side of the box. I wander what purpose they are there for? Se picture.
Is there any who can help?
Re: Heater air distributor
« Reply #1 on: April 07, 2016, 13:43:21 »
Its the connector for the glove compartment light.
Peder
« Reply #2 on: April 07, 2016, 14:47:34 »
Aha. You see, the air distributor was missing when I bougth the var. But the light in the glove box is ok anyway.
Thank for the information.
alchemist
  • USA, NY, GRAND ISLAND
« Reply #3 on: April 10, 2016, 02:24:10 »
Mine has no connectors on the side of the heater housing. However, Similar connectors do exist out side the housing, on the side of the duct, with 2 electrical wires, one of which is ground and the other goes to the Glove Compartment. If your glove compartment light is working, most likely that you have the same set-up like mine. Then you just ignore the connector on the housing you bought. That means that the housing you bought is different than your original housing.
