My '69 280sl just started to overheat at idle. At normal driving the temperature is fine. When it is overheating at idle I can rev the engine while in neutral and the temperature drops right back down. All belts seem to be fine and the fan is spinning at idle and spins faster when I accelerate. I'm assuming fan clutch is fine.
My first guess was a bad thermostat but that doesn't make sense if I can rev the engine and the temp drops back down. If it was stuck closed I don't think I would be able to do that.
Any suggestions?
