Become a
Full Member
Emergency Contact List
pedal linkage......
Topic: pedal linkage...... (Read 3731 times)
erickmarciano
Associate Member
Gold
Canada, Quebec, montreal
pedal linkage......
April 12, 2016, 22:46:04 »
Hi Guys
got all the engine linkage set well but from progressive part down I don't think its set well.
the rod going down to the pivot is under tension when I try to connect to the progressive linkage on intake.I tried lengthening it but its over extended no thread on the rod left.
should I lengthen rod #45?
the gas pedal also feels like its under tension.
anyone got a link on adjusting the pedal---firewall link---#45---vertical link to progressive block on intake?
in what order?
thanks
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Associate Member
Platinum
USA, CA, Encinitas
Re: pedal linkage......
April 13, 2016, 01:59:37 »
You may need to adjust the nut and bolt #51 and #53 to get your pedal and cross rod on the firewall in the proper position. The lever in this location is slotted for adjustment.
erickmarciano
Associate Member
Gold
Reply #2 on:
April 17, 2016, 00:36:47 »
I am having a real hard time adjusting the pedal/ spring position/ link from engine to the progresive part
Cant find the procedure anywhere
My car is a manual
Last Edit: April 17, 2016, 04:01:26 by erickmarciano
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Full Member
Platinum
USA, OH, Blacklick
Reply #3 on:
April 24, 2016, 01:01:09 »
Erick,
When the accelerator pedal is on the floor stop, the intake venture flap should be full open. The linkage tour should get you through the rest.
erickmarciano
Associate Member
Gold
Reply #4 on:
April 24, 2016, 04:00:54 »
There are 3 adjustments I am confused on how to adjust ( what to do first)
1-The firewall one with the pedal and what hole to place the spring
2- the rod going to the engine pivot
3- rod from engine pivot to intake
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
pedal linkage......
