Author Topic: Finish colour of top casting on 4 speed transmission  (Read 3221 times)
gtait
  • Canada, BC, Sooke, BC
« on: April 15, 2016, 18:10:21 »
I am painting my engine and bracket etc.  and wondering what is the OEM finish for the top casting on the 4 speed standard transmission. Most of whatever was on it has worn off, but it does look to have reminits of a gold or brass colour.  Just wanting to do it correctly and am looking for advice.
Thank you
Gil
Gil
1964 230SL Standard
Re: Finish colour of top casting on 4 speed transmission
« Reply #1 on: April 15, 2016, 20:23:30 »
The top of a standard trans is made of aluminium. This will darken over time and turn black. If you are unable to clean it I suppose you could use aluminium colored paint.
 The box is green. I use etching primer which is very close to the original color and it may in fact have been primer that was used when the trans was made.
« Last Edit: April 16, 2016, 03:45:54 by Benz Dr. »
gtait
« Reply #2 on: April 15, 2016, 22:09:38 »
Thank you.  I will clean and leave raw.   I have learned a ton from all your posts.
Gil
Gil
1964 230SL Standard
« Reply #3 on: April 16, 2016, 21:02:46 »
This is the color of Ditzler DP40 epoxy primer. I wet it down to show the true color.  Gloss is satin when new.
gtait
« Reply #4 on: April 17, 2016, 06:29:39 »
Thanks for the help.  The body of my transmission is actually in remarkable shape and it the green paint is in great condition. Only the top casting shows a little oxidation.
Having a great time bring my 230 back to life. It has not been on the road since 1981. This site is amazing.
Gil
Gil
1964 230SL Standard
