Author Topic: Engine rebuild manual or diagrams SL230 Pagoda  (Read 3527 times)
rigger29
« on: April 26, 2016, 13:10:16 »
I have a 1964 SL230 Pagoda and I need to bebuild the engine (Crank and bearings / Top end cam and valves).  Is there a manual available or diagrams online that show the parts and configuration.  Or somewhere I can take it with confidence to have the rebuild work done.
mbzse
Re: Engine rebuild manual or diagrams SL230 Pagoda
« Reply #1 on: April 26, 2016, 16:45:56 »
Quote from: rigger29
....rebuild the engine.../...  Is there a manual available../..
Certainly, all specifications, tolerances etc are in the workshop manual (1959 edition with additions) and the book of tables.
See our Wiki ("Tech Manual") under Documentation, and here:
https://www.mercedes-benz-classic-store.com/en/literature-und-media/technical-literature/
/Hans S
/Hans S
Fintail
« Reply #2 on: April 26, 2016, 17:59:34 »
Hi Rigger
Are you sure it needs a rebuild?Many and most times I have visited owners cars to find set up was the cause of all ills. Have you had compression tested is old pressure pegged at 45 above tickover.
kind regards
John
Dave H
  • United Kingdom, England, Durham
    • Dave H
« Reply #3 on: April 27, 2016, 09:46:29 »
Here is a link to an engine rebuild guide with lots of technical specs.
http://s272261875.websitehome.co.uk/gal251981502/pdf/M180_rebuild_guide.pdf
Modify message
Mercedes 250SL    1967
Mercedes 250SLK  2014
Alfa Romeo 166 3.2 Ti
Fiat 500
rigger29
« Reply #4 on: April 27, 2016, 14:23:53 »
Hi John,
Yes I bought it from the USA with this problem in mind.  Did the compression tests without plugs in and there is a definite knock from bottom end.
Cheers.......Mark
rigger29
« Reply #5 on: April 27, 2016, 14:38:28 »
Thanks Dave,
Thats a great start.  I believe I will also need information regarding the set up of "6 plunger fuel injection pump".
We don't know how far we will need to delve into things until we get the engine out.  Hopefully head and crank (and associated part) is all thats necessary.  If you know where to get other relevant information with regard to the engine I'd really appreciate it.
This is a great help.
Cheers..........Mark
rigger29
« Reply #6 on: April 27, 2016, 14:39:41 »
Thanks Hans,
Will look through.
Cheers..............Mark
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #7 on: April 27, 2016, 17:04:47 »
Thanks Hans and Dave for sharing ... Great stuff !
Cheers,'
Dieter
