with our official
Pagoda SL Group logo
from our official partner.
Electrical and Instruments
Unknown Relay R/H Engine compartment
Topic: Unknown Relay R/H Engine compartment (Read 3842 times)
CJHenderson
Full Member
Silver
USA, AR, Benton
April 28, 2016, 18:37:24 »
Have a relay on the right side of engine compartment just aft of the shock cover. Looked in Chilton manual cannot locate it.
1950 MG-TD
Vendor
Platinum
United Kingdom, England, Richmond
Re: Unknown Relay R/H Engine compartment
April 28, 2016, 18:55:02 »
Voltage regulator
Stick
www.colinferns.com
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #2 on:
April 28, 2016, 19:03:00 »
Great thanks
1950 MG-TD
Associate Member
Gold
USA, West Seattle, WA
'69 280SL,Signal Red,
Reply #3 on:
April 28, 2016, 23:47:48 »
I found when I checked the voltage with the alternator turning, it would read 12 volts. It should read about 13.8 volts. So I opened it up and turned the little screw until it read 13.8 volts. I wonder why my battery is now happier.
awolff280sl
Full Member
Gold
USA, FL, Sarasota
Reply #4 on:
May 01, 2016, 11:17:45 »
I was not aware that the output voltage is adjustable.
Where is this little screw located?
Andy Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Associate Member
Platinum
USA, CA, Encinitas
Reply #5 on:
May 01, 2016, 15:04:46 »
Andy, If you remove the top cover you will see the adjustment. Cleaning the contacts often helps as well. Only the Original regulators have this adjustment. The replacement ones are not adjustable.
