Author Topic: Exhaust / Muffler rubber rings  (Read 4358 times)
PeterPortugal
  • Portugal, Faro, Lagoa
« on: April 28, 2016, 20:08:04 »
Hi Guys,
Are there any tricks or tips to fitting the rubber rings which support the exhaust / muffler? I am referring in particular to that long one which fits in a recess in the middle of the system.
Regards
1963 220se Cabrio
1968 280se Coupe
Re: Exhaust / Muffler rubber rings
« Reply #1 on: April 28, 2016, 21:08:04 »
What's real handy for this is a kind of 'hook thing' with a handle, something that lets you stretch the rubber donut while you work it onto the bracket. I use a large screwdriver but there are special-purpose tools for this.
« Reply #2 on: April 28, 2016, 21:30:45 »
Love the technical language on the forum - "hook thing"
A cotter key pulling tool may be what you can use. Here is one example
http://www.searsoutlet.com/Cotter-Key-Extractor/d/product_details.jsp?pid=12335&mode=seeAll
hkollan
  • Spain, Castilla-La Mancha
« Reply #3 on: April 29, 2016, 06:10:43 »
I use a tool like Cees describes, similar to this:
http://www.ebay.de/itm/Auspuff-Kfz-Spezial-Werkzeug-Ziehhaken-Abzieher-Gummi-Zughaken-Montagehaken-BGS-/261972568062?hash=item3cfec827fe:g:LtIAAOSwZ8ZW2XKk
Sometimes together with a large flat headed screwdriver for prying the rubber ring
In place.
Non original rubber rings are sometimes a harder to work with than MB rings.
Regards
Hans
Hans K, Cuenca, Spain
UJJ
  • USA, CA, Grass Valley
« Reply #4 on: April 29, 2016, 12:16:10 »
Heating them up in hot water helps too.
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
Jack Jones
  • Canada, ON, Milton
« Reply #5 on: April 29, 2016, 12:30:54 »
My experience is the Mercedes rubbers are more pliable and do not crack as quickly as the aftermarket o-rings. I have seen aftermarket o-rings crack in less that 2 years so spend the $1.00 more.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
« Reply #6 on: April 29, 2016, 13:54:30 »
Install the rubber ring and the upper part of the hanger first, then raise the muffler and attach the bottom part of the hanger.
PeterPortugal
« Reply #7 on: May 01, 2016, 06:23:56 »
Guys,
Thanks for your posts.
The 4 round rings which are fitted to the rear box are relatively easy. Mine came as part of a non oem exhaust kit so following your advice l will be careful to check these for condition on a regular basis.
The long one in the middle though is the stuff of nightmares. This one is an original from MB (A1114920082) - my car is a W111. After a bit more research I suspect that the W113 does not have this ring.......and I can understand why. The hooks for it are inside a recess in the floorpan. The recess is just big enough to get the rubber ring in. I found it impossible to apply any leverage to stretch the rubber once it is in the recess and fitted over one hook.
However I will invest in one of the tools suggested (thanks for the link Hans) and try the hot water technique. What are we talking about here - boiling point? I guess these rubber rings are designed for taking heat bearing in mind the application.
Regards
1963 220se Cabrio
1968 280se Coupe
« Reply #8 on: May 02, 2016, 14:37:19 »
Doesn't have to be that hot. After all, you have to hold these things when you take them out. 150*F should be plenty to make them pliable. Let them sit in the hot water for a while because you want the part to get warm all the way through. Rubber is an insulator after all.
sandcrab59
  • USA, MA, Lunenburg
« Reply #9 on: May 03, 2016, 23:49:40 »
Hi Jon
That tool you described is used by Joe for removing radiator hoses from the radiator.
I purchased one from Harbor Freight  and it works greats on the radiator hoses. It sure beats a screw driver that I was using for the last 50 years.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
