I have a 1966 230SL with a 4-speed manual transmission. It was running well until I tried to tweek it a little. Now, the engine idles at about 1800 rpm, and I can't get it down.
Basic info:
European version
051 distributor
New points, cap, rotor, spark plugs and cables
At 1800 rpm, the dwell is 39 and the timing is at 12 BTDC with vacuum connected.
New vacuum tube installed- it was the purple colored from Mercedes Classics. A suction/blow test indicated the diaghram was still intact.
FIP rack moves smoothly in both directions when using a threaded rod.
The linkage tour procedure was followed when getting the car running well with a 750 rpm. The linkage rods have not been changed since the RPM problem occurred.
The fuses (in the engine panel box) were visibly inspected, with no problems seen.
I tried to tighten the bolts on the thermo time switch, and broke the insulation; I installed a replacement unit from Authentic Classics with the plug-on system. A quick check showed the resistance to be 38 ohm (g) and 12 ohm (w) with the water temperature gauge showing 55 degrees C (using the dashboard water gauge).
I inspected/cleaned the CSV. I cleaned the spray nozzle with a fine wire. There was no fuel coming out of the inspection hole in the CSV when the fuel pump was on.
I turned the FIP idle control valve CW to the end then 25 clicks CCW; the high rpm at idle continued. An additional 10 clicks CCW (in two stages) did not change the high rpm idle point.
What should I check next?
Thanks in advance for your assistance.
Best regards,
Ken
1966 230SL euro, 4-speed.
