Author Topic: A1103501475: Thrust arm repair kit content  (Read 7366 times)
pagodarune
  • Norway, Ostfold, Trogstad
« on: April 29, 2016, 07:28:32 »
Does anyone know the exact content of the thrust arm repair kit (A1103501475)? The picture in the EPC is not always correct.
I am going to order parts, and want to know what additional parts I need to order.
Rune R
1966 230SL
WRe
pagodarune
Re: A1103501475: Thrust arm repair kit content
« Reply #2 on: April 29, 2016, 09:21:24 »
Hi WRe
The parts in your picture are what I would expect this kit include.
The picture from EPC is not very good.
Rune R
1966 230SL
WRe
mbzse
« Reply #4 on: April 29, 2016, 15:41:01 »
Quote from: pagodarune
.../... the exact content of the thrust arm repair kit (A1103501475)
Note that the large dia trailing arm bolt, key width 36mm, supplied nowadays is made with a flat face.
I save and refurbish the originals; I think it is a nice touch and makes quite a visible difference there on the rear axle.
I suppose, the "hollowed out" original version bolt is too expensive to produce today. See comparison photo attached, "current vs. original".
Note, I borrowed the pic "Trailing arm bolt", not my car. The bolt should be tightened to >300NM (some 225 lbft); the thin metal washer shall then be folded on one hex side, to lock the bolt in position.
To remove the bolt, a tool such as shown on attached pic is useful
Note No 2: Be sure to only fully fasten these four bolts once the car is on its wheels; suspension in "normal" position, otherwise you introduce tension in the rubber, gives inferior ride quality and short life for rubber components...
/Hans S
« Last Edit: July 22, 2017, 12:21:59 by mbzse »
/Hans S
pagodarune
« Reply #5 on: April 29, 2016, 20:34:40 »
WRe: I have seen the SLS kit. I prefer to buy original MB parts, therefore I wanted to find out if the MB repair kit included all the necessary parts.
Hans: Thank you for pointing out the difference between new and old bolts. I will try to rescue my old ones. One of them was slightly rounded during disassembly. What is the correct finish on these bolts? I can not see any yellow cad/zinc on the bolts that I removed. I believed that they were black phosphate or similar.
I used the same tool, together with a clamp, for disassembly. Even with this setup, I had to heat the bolt to get them loose.
Rune R
1966 230SL
mbzse
« Reply #6 on: April 29, 2016, 20:58:36 »
.../...I wanted to find out if the MB repair kit included all the necessary parts
It certainly does. Perhaps I can take a pic of it for here, tomorrow
Quote
I will try to rescue my old [bolts]. One of them was slightly rounded.../...
I guess you know BjarneK in Oslo; I'm sure he can supply NOS bolts of this kind to you
Quote
.../...the correct finish on these bolts.../...I believed that they were black phosphate or similar
That's right, they were. Just that when one refurbishes parts, it is convenient to make them all yellow cad (anti corrosion, one batch to vendor etc.). From factory, front and rear axle assemblies were painted flat black all over anyway, screws, fittings and all.
Some fellow restorers of our cars like to keep some yellow, it sure stands out nicely against the black   ;)
/Hans S
« Last Edit: April 29, 2016, 21:14:10 by mbzse »
/Hans S
mbzse
« Reply #7 on: April 30, 2016, 21:21:15 »
.../...the exact content of the thrust arm repair kit (A1103501475)
See image attached. Compare with photo from WRe. The two M14 fine pitch Nylock nuts are included for the mount at the thrust arm front end. There you most likely need additional new rubber doughnuts.
/Hans S
« Last Edit: May 03, 2016, 11:52:58 by mbzse »
/Hans S
pagodarune
« Reply #8 on: May 01, 2016, 18:41:54 »
Thanks Hans. I can do some shopping now that I know what is in the kit.
I have found some pictures with yellow cad bolts, and I agree that they do look good. Now I have to decide whether to keep it original or good looking.
Rune R
1966 230SL
mbzse
« Reply #9 on: May 01, 2016, 20:59:21 »
.../... they do look good. Now I have to decide whether to keep it original or good looking
Indeed. These are pleasant choices... A comforting fact is, one can always paint the bright parts suitably flat black at any later date   8)
/Hans S
/Hans S
