Author Topic: Speedometer Question  (Read 4895 times)
lorirobin
« on: April 29, 2016, 19:18:17 »
I have a 71 280SE 3.5 which had a 3.69 rear differential which I changed to a 3.27 from a 280SE 4.5.
Now the speedometer reads low along with the odometer.
Instead of having the speedometer re-calibrated could I install a speedometer from a 280SE 4.5
which should correct the problem. My understanding is Mercedes calibrated the speedometer to the
rear differential ratio. I guess I could just live with it, but I'd rather not.
Comments, suggestions?
Jeff
homerj40
Re: Speedometer Question
« Reply #1 on: January 12, 2017, 01:38:28 »
Hi Jeff,
Have you talked to North Hollywood Speedometer? They specialize in VDO work on classic cars, they might be able to recalibrate it.
http://www.nhspeedometer.com/directions/
Good luck,
Darren
« Reply #2 on: January 12, 2017, 03:53:55 »
The 3.5 coupe has gauges like a 113 and the 4.5 has 108 gauges which are not the same at all. It may be that parts are interchangeable.
450sl
« Reply #3 on: January 12, 2017, 11:32:04 »
The correct ratio should be  (inkt) stamped on the back of the gauge ...........
