Author Topic: Rear axle pivot pin and bushing  (Read 3654 times)
cfm65@me.com
  • Cape Town, South Africa
« on: April 30, 2016, 18:14:31 »
Hi Gents,
Is it possible to install the rear axle pivot pin and associated metalistic bush without dropping the complete axle? All my rubber joints and bushes seem to be in good condition, except for the metalistic bush.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Re: Rear axle pivot pin and bushing
« Reply #1 on: April 30, 2016, 23:00:25 »
You can but you will be fighting it the whole way because of the center axle spring tension, the body, and the lack of room. You will also be unable to correctly position the carrier because the measurement for fore and aft alignment is taken horizontally from the top of the carrier-The body of the car makes this impossible. But you might be able to get it close.
mbzse
« Reply #2 on: May 01, 2016, 00:04:55 »
Quote from: cfm65@me.com
.../...Is it possible to install the rear axle pivot pin and associated metalistic bush without dropping the complete axle.../...
Some relevant info in this thread: http://www.sl113.org/forums/index.php?topic=23899.msg171130#msg171130
/Hans S
/Hans S
cfm65@me.com
« Reply #3 on: May 01, 2016, 01:32:04 »
THK Tyler and thnks Hans,
Point taken. I did this job many years ago on a 190SL, but cant remember the detail.
I'll drop the rear end in due coarse.
Regards
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
