Author Topic: tires  (Read 12504 times)
Michaelg
tires
« on: May 04, 2016, 11:29:45 »
The tires on my 1970 280 SL look like bike tires!!! 185 / 75 R14 Uniroyal tiger paw white walls.
I would like to put a little more tire on the car to fill out the wheel well.
I am open to sudgestions.
Cheers
mmizesko
  • USA, OH, New Albany
Re: tires
« Reply #1 on: May 04, 2016, 12:02:23 »
Check with kayvan.  I think he put 205's on his. They are blackwalls tho.
Mike
1970 280SL 291H Dark Olive
Re: tires
« Reply #2 on: May 04, 2016, 12:50:08 »
I had 205's on mine for a number of years, then switched to 185's which look much better on the car. May I suggest you also try the 'search' function as there are tons of posts, and hence suggestions, in there for you.
Jowe
Re: tires
« Reply #3 on: May 04, 2016, 19:15:07 »
Johan
Re: tires
« Reply #4 on: May 04, 2016, 21:11:23 »
I have middle of the road 195/70R14. Fit and look good.
Re: tires
« Reply #5 on: May 05, 2016, 04:07:27 »
That's because they are the best size to use.
ghenne
  • Canada, ON, Toronto
Re: tires
« Reply #6 on: May 05, 2016, 09:53:39 »
I've had 205/70 blackwalls on my car for the past 35 years. I like the beefier look, but choice of tires is limited and expensive.
195/70 has a 3.5% speedometer error, while 205/70 has a 1.4% error, so they're a bit close to the original diameter.
Dan, why do you like 195/70?
perry113
  • USA, NY, Rensselaer
Re: tires
« Reply #7 on: May 05, 2016, 10:09:53 »
195/75R14's will keep the same aspect ratios as the original 185/14. I went with the white wall Optima H724. They were very reasonable in price. I have no regrets on this decision.
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
Pinder
  • USA, NJ, Edison
Re: tires
« Reply #8 on: May 05, 2016, 11:59:22 »
The Hankook Optima just mentioned by Perry is what I have on the 69 and they are very good and extremely well priced (and have the white strip). Walmart had a great price for the tire and also cheap installation.  Other places had similar price but mounting / balancing was more. I think total for 4 tiers was around $250 to $280 installed.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Re: tires
« Reply #9 on: May 05, 2016, 14:06:15 »
I've seen some cars where 205 tires would rub on the inner fender. Likely a different problem but a problem none the less.
vande17941
  • USA, CA, Irvine
Re: tires
« Reply #10 on: May 30, 2016, 02:25:01 »
I had 205s.....rubbed on the exhaust occasionally and on the inner Fenders
Switched to the Hankook Optimo white walls from America's Tire / Discount Tire a month ago for $46 each. Looks great. Handles well at 34psi
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
m300cab
  • USA, Pennington New Jersey
Re: tires
« Reply #11 on: May 30, 2016, 15:13:06 »
I have used 205 70 14" and never had a problem, I also like the look with a slightly larger tire.
Michael Parlato
Re: tires
« Reply #12 on: May 30, 2016, 15:20:33 »
Go with a 15" wheel and MB hubcap combo or a 15" bundt 205/65/15 modern tire with custom WW.
vande17941
  • USA, CA, Irvine
Re: tires
« Reply #13 on: June 01, 2016, 18:44:04 »
I noticed, without power steering, the effort required while parking at slow speed is quite a bit higher with the 205s. I had Uniroyal 205 blackwalls. Switched them out for 195/75 Hankook Optimo white walls. They look better, and even though skinnier....they handle better because the tire is a better design and composition. People absolutely LOVE the white walls. "Spectators" mention the tires every time they admire the car.
UJJ
  • USA, CA, Grass Valley
Re: tires
« Reply #14 on: June 02, 2016, 13:58:13 »
I got these brand new 15" Bundt rims. I am planning to mount them with 205/65-15" BW tires.
Once I have them installed I'll report back. (Hopefully with good news).
Currently I have 205/70-14" WW installed with no issues.
Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
Re: tires
« Reply #15 on: June 06, 2016, 01:44:30 »
Hauser has the right idea.  looks and performs excellent.  no regrets
UJJ
Re: tires
« Reply #16 on: June 13, 2016, 21:17:55 »
Got these mounted this weekend. I like how the car handles now, big improvement.
.How about the looks, what do you think? I cannot decide, I like both looks hubcaps and alloy.
Urban Janssen
Grass Valley, CA
173 anthracite grey
Re: tires
« Reply #17 on: June 13, 2016, 21:43:48 »
Like them both. Leave the "Bundt" on for driving, Switch to caps for show. :)
I think the black walls look better on the darker color cars. Esp with a black soft top.
Re: tires
« Reply #18 on: June 14, 2016, 04:05:24 »
Urban the car looks awesome!!
Anyone  wanting to do this should make sure that the rear axel is centered.
http://www.sl113.org/forums/index.php?topic=6689.msg43216#msg43216
Pinder
  • USA, NJ, Edison
Re: tires
« Reply #19 on: June 16, 2016, 12:02:55 »
I agree both look good but I have a slight preference to the hubcaps.
Ulf
Re: tires
« Reply #20 on: June 18, 2016, 20:17:08 »
Just made the change from 205's to 185's today, certainly less beefy looking, but a much better ride - like floating on air :-)
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
Re: tires
« Reply #21 on: June 19, 2016, 03:00:26 »
Ulf, are you suggesting that Uhlenhaut and his crew knew what they were doing? 😳
Ulf
Re: tires
« Reply #22 on: June 19, 2016, 14:28:52 »
I sure am :-)
2008 Jaguar XF 3.0
2005 Mini Cooper
Re: tires
« Reply #23 on: June 19, 2016, 17:58:54 »
These are interesting.  They are light truck tires which means they should have stiffer sidewalls AND they are available in 185R14!
 Not to mention a cool retro European tread design.
http://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=Y356&partnum=8R43568&vehicleSearch=false&fromCompare1=yes
Re: tires
« Reply #24 on: June 20, 2016, 17:47:07 »
I had those Yokohamas on my 89 Westfalia camper before I upgraded my rims. Good tires but noisy. The tread pattern on the sidewall is kind of an eyesore.
