Author Topic: Air conditioner question  (Read 5991 times)
CJHenderson
  • USA, AR, Benton
« on: May 10, 2016, 17:58:52 »
I'm not sure if this is a dealer installed type or after market air conditioner.
1950 MG-TD
mario
Re: Air conditioner question
« Reply #1 on: May 10, 2016, 19:47:31 »
That appears to be a Frigiking dealer installed A/C.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: May 11, 2016, 21:02:47 »
It's coming out and will not be put back in. When they installed this the mechanics removed the 4 climate control levers and disabled any way of getting heat in the car.
1950 MG-TD
« Reply #3 on: May 12, 2016, 06:22:34 »
Try moving the main water valve. It is under the hood, beneath the rubber plug on the top of the firewall.
« Reply #4 on: May 12, 2016, 09:35:55 »
they most likely didn't remove the levers but rather the levers simply vaporized.  They are made of some funky plastic (Celluloid?) and they tend to fall apart.  All that was left of mine when I got my car was some white ash like powder on the carpet.  The system if intact has become quite valuable so I would treat it carefully and either store it properly or sell it to someone else.
« Last Edit: May 12, 2016, 09:40:33 by Shvegel »
CJHenderson
  • USA, AR, Benton
« Reply #5 on: May 13, 2016, 15:16:29 »
Here is a photo of the area that Ja17 referred to and I'm not sure if this unit to the left of the firewall holes is the valve he is talking about.
1950 MG-TD
« Reply #6 on: May 17, 2016, 13:31:53 »
The valve is visible if you look down into the upper firewall hole.  you should be able to see the cable going into a lever with a screw on top.  See if you can pry the lever back and forth.  Don't go crazy tring to get it to move.  Much better to take it apart and free it up than destroy it.
The unit to the left of the holes is the neutral safety switch witch is used to keep the car from starting unless it is in Park or Neutral.
CJHenderson
  • USA, AR, Benton
« Reply #7 on: May 18, 2016, 18:08:31 »
The valve is not there.
1950 MG-TD
CJHenderson
  • USA, AR, Benton
« Reply #8 on: May 18, 2016, 18:10:42 »
What is this selector next to the hood release?
1950 MG-TD
MikeL43
« Reply #9 on: May 23, 2016, 19:04:52 »
Your AC looks identical to the Kuhlmeister unit installed on my 67 250 SL by the dealer when it was originally purchased in January of 1968.  I know some units that looked identical were labeled Frigiking which I think was the company that actually manufactured the Kuhlmeister AC unit.  I just had my AC completely reworked and had a new sanden compressor and new condenser installed (I kept all the old parts).  Since I'm in Florida this is a must have item for summer driving along with the hardtop.  I would be reluctant to remove the AC as it is a value enhancer.  It's amazing, down here we put the tops up in the summer and down in the winter, different strokes for different folks.
Mike L.
RonB
  • USA, MN, Cottage Grove
« Reply #10 on: May 28, 2016, 02:45:34 »
Hi Mario - I am really interested in the inside part of your air unit. Also would be in interested in the bracket
My wife Nancy really needs air in the summer, ton of allergies.
Just let me know.
Previously FULL Member twice with over 500 post
71 280SL - SOLD on BAT
97 E420      SOLD
85 300D      SOLD
85 R107 380SL
07 Volvo S60
