Author Topic: Trailing arms  (Read 4297 times)
cfm65@me.com
  • Cape Town, South Africa
Trailing arms
« on: May 10, 2016, 18:48:53 »
Hi Guys,
Has anyone noticed that the left trailing arm is positioned further inboard than the one on the right?
The left trailing arm is about 5 1/2 inches inboard of the lower shock mounting and the one on the right is only 4 inches inboard of the RH shock mount. I wonder why
Although I seem to recall that way back(30 years ago) I noticed that on the 190 SLs as well.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Re: Trailing arms
« Reply #1 on: May 10, 2016, 21:35:17 »
I am guessing it has to do with the pivot point of the axle being biased to the right.
Re: Trailing arms
« Reply #2 on: May 11, 2016, 04:00:22 »
Yes, it is harder to get tools in the side that is closer.
cfm65@me.com
Re: Trailing arms
« Reply #3 on: May 11, 2016, 15:54:20 »
Yep, a 36mm socket + reducer drive to 1/2 inch rathet does not fit on the far R/H bolt. I managed to get a huge 36mm spanner from our local hire shop in order to undo the far RH bolt.
All trailing arm rubbers replaced and the arms back in position.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
Re: Trailing arms
« Reply #4 on: May 11, 2016, 16:05:26 »
I bought a socket and then we modified it to fit this application. We cut close to half the length of the socket so it would fit.
« Last Edit: May 11, 2016, 17:08:07 by Benz Dr. »
mbzse
Re: Trailing arms
« Reply #5 on: May 11, 2016, 16:12:30 »
Quote from: ja17
Tool suggestion in this thread:
http://www.sl113.org/forums/index.php?topic=24258.msg173855#msg173855
/Hans S
/Hans S
Re: Trailing arms
« Reply #6 on: May 11, 2016, 19:44:31 »
If you look at the chassis drawing in the technical manual this offset is clear to see.
cfm65@me.com
Re: Trailing arms
« Reply #7 on: May 12, 2016, 10:17:57 »
Thank you Gents,
All done.
Regards
Chris
« Last Edit: May 14, 2016, 10:18:00 by cfm65@me.com »
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
Re: Trailing arms
« Reply #8 on: May 13, 2016, 19:58:18 »
The other benefit to facing off the socket is that you lose the chamfered lead in on the socket. You then get full socket contact on the bolt head. These bolts have a narrow width head and considering the required torque, you want all of the contact surface you can get.
