Author Topic: Trivia Question for the Parts Geeks  (Read 5972 times)
ctaylor738
  • USA, VA, Falls Church
« on: May 11, 2016, 12:43:23 »
What is the largest quantity for a single part used on Pagodas, and what is the part?
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
mmizesko
  • USA, OH, New Albany
Re: Trivia Question for the Parts Geeks
« Reply #1 on: May 11, 2016, 14:00:55 »
Guess:  10mm bolt or the stainless screws that hold the rockers on.
Mike
1970 280SL 291H Dark Olive
« Reply #2 on: May 11, 2016, 14:10:40 »
and here is another question...what's the source of the correct answer?
ctaylor738
« Reply #3 on: May 11, 2016, 14:22:11 »
Mike M - not even close.
Michael S - the EPC or the dealer parts book.
Chuck Taylor
1963 230SL #00133
Falls Church VA
« Reply #4 on: May 11, 2016, 19:31:12 »
Nice quiz. What comes to mind:
- hog rings in the seats (I have no clue how many are needed)
- clips to put the chrome trim on the body
- transmission pan bolts
Has to be more than 12, because there are lots of engine parts that are that number. I wonder what the correct answer is!
ctaylor738
« Reply #5 on: May 11, 2016, 21:43:48 »
No, no, no!
Hint - three figures.
Chuck Taylor
1963 230SL #00133
Falls Church VA
« Reply #6 on: May 11, 2016, 22:46:19 »
Self tapping screw, probably around 6g 10mm??
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Baybear
  • USA, VA, Midlothian
« Reply #7 on: May 11, 2016, 23:55:51 »
How about a cylinder roller?
1809810086
Will
Will Milby
1970 300SEL 6.3, 1971 280SL, 1972 300SEL 4.5, 1972 Super Beetle, 1998 SL500, 2010 350 GLK, 2012 SLS AMG
« Reply #8 on: May 12, 2016, 00:16:54 »
Nah. It's paint or paint products. As in DB 180............
ctaylor738
« Reply #9 on: May 12, 2016, 01:29:28 »
We have a winner.  Will Milby nailed it.  The roller bearings in the sliding joint.  Here's a picture of 38 of them.  Be careful if you take this apart.
Chuck Taylor
1963 230SL #00133
Falls Church VA
« Reply #10 on: May 12, 2016, 06:12:10 »
What? 38 is the largest quantity for a single part used on Pagodas? :o
How many of these balls are there per car?
ctaylor738
« Reply #11 on: May 12, 2016, 12:11:20 »
114.  Three sets of 38.
Putting the slide joint back together is a challenge.
Chuck Taylor
1963 230SL #00133
Falls Church VA
mmizesko
« Reply #12 on: May 12, 2016, 13:14:16 »
I know I am ignorant, but this is a teaching moment.  What does this part slide?  Where is it on the car?
Mike
RAY
  • United Kingdom, England, Bromley
« Reply #13 on: May 12, 2016, 17:10:23 »
Just so your not alone Mike. What does it slide and where ?
« Reply #14 on: May 12, 2016, 20:18:55 »
AFAIK it's on one side of the rear axle and allows the axle to adapt its length depending on the movement up and down of the body relative to the wheels (if that makes sense).
« Reply #15 on: May 12, 2016, 20:32:48 »
The slider is part of the universal joint that resides in the big black boot on the rear axle. It allows for the vertical movement of the right rear wheel independent of the left. It allows for the change in the effective length of the axle shaft as the wheel moves up and down.
The 230 SL universal  joint is not as beefy as the later cars and has only 37 rollers per segment as opposed to 38.
Those of you who saw the Kiwi Ponton article in the latest (MBCA) Star mag. will see that this is the joint that failed damaging the axle tube and diff at the same time.
