Author Topic: Valve Seal Tool  (Read 2306 times)
Ron500E
Valve Seal Tool
« on: May 13, 2016, 05:06:54 »
Does anyone have a Genuine Mercedes valve seal installation tool that they would sell, or rent?
Ron
Re: Valve Seal Tool
« Reply #1 on: May 13, 2016, 08:45:15 »
Its easy enough to get one turned up on a lathe; there's a diagram in the BBB I think.
Re: Valve Seal Tool
« Reply #2 on: May 14, 2016, 07:53:41 »
You can use an old valve guide to push the seals down in place. With the intake valves, you should also use the plastic installation sleeves provided with the valve seals.
