Author Topic: Dented Air Cleaner Housing  (Read 3381 times)
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
« on: October 30, 2004, 17:09:10 »
My air cleaner housing, a black sheet metal can, has a dent where the air intake canal is. Because of the location of the dent, I can not just pound the dent out from the inside. The dent does probably not affect the function and it is not visible with the air cleaner installed. Any bright ideas anyone? I found a used air cleaner from a 230SL and bought it. I assumed, that it was the same, but it is quite different. Yes, I know, it's those first 3 letters of the word "assumed" that get you.
1969 280SL,Signal Red,  Retired engineer, West- Seattle, WA
« Last Edit: October 31, 2004, 17:19:30 by theengineer »
'69 280SL,Signal Red, 09 cam, License BB-59U
'67 230SL, 113042-10-017463 (sld)
'50 Jaguar Roadster XK120, #670.318 (sld)
tired engineer, West-Seattle,WA
Re: Dented Air Cleaner Housing
« Reply #1 on: October 31, 2004, 13:02:28 »
Perhaps one of those dent removal shops, Dent Wizard or the like??
« Reply #2 on: October 31, 2004, 18:26:21 »
Leave it to "The Engineer" to include a polished chrome, rotating Mercedes Benz Star in his signature.
Very nice!
1964 356C
« Reply #3 on: November 01, 2004, 09:27:10 »
I don't have any great DIY ideas, but if you feel like spending a few bucks, a body shop should be able to pull the dent out for you pretty easily using a stud welder, sometimes called a "spitznagel".  A nail-like stud is welded to the dent, then a slide hammer is used to grab the stud and pull it out.  When done, the studs are ground off.
Malc
« Reply #4 on: November 02, 2004, 14:53:49 »
Blocks of wood, cut to shape
A long bar, pipe etc
Clamp it down using ratchet straps etc
gently lever the dent out using the wood as rests
Should work,
if your careful
Malc
