OK, I had them sorted - so far at least.
Had the old seals removed, each valve guide roughed up around the top and had the seals refitted with super glue. Took forever as each one needed to be checked that the glue went only where it should do Used a 2 pack system, glue and hardener.
One thing i learnt is that the seals seems to be made of some kind of polythene. Many glues do not stick polythene at all. Araldite for example does not. So i think super glue is the only thing, and even some super glues do not stick some plastics. Found one that does. Seems to be working.
This is the kind of glue we used.
https://www.youtube.com/watch?v=aZlKvxBRNsA Hope that helps.
Paul.
