Author Topic: engine up grade  (Read 7362 times)
Madmerc
engine up grade
« on: May 20, 2016, 06:39:26 »
hi all just a thought here i have a 1970 300sel with a 6.3  in it all origanal  but body needs a lot of work  ,was thinking what it would be like to  drop the running gear in my 1963 220 se coupe  any sugestions thanks
Re: engine up grade
« Reply #1 on: May 20, 2016, 14:20:17 »
I had a 220SEb Cab in once with a 6.3 installed. It even had the air suspension system which you pretty much need with the weight of that big engine.
At least it went fast in a straight line - not much for corners though! :o
1988 560SEC
Madmerc
Re: engine up grade
« Reply #2 on: May 20, 2016, 22:16:42 »
Hi dr Benz  are the sub frames the same and will if fit in  any advice thanks
280SEC
Re: engine up grade
« Reply #3 on: June 17, 2016, 10:06:21 »
As I know the 6,3 has a bigger tunnel for the automatic.
Greets Konny
perry113
  • USA, NY, Rensselaer
Re: engine up grade
« Reply #4 on: September 15, 2016, 02:28:18 »
Although I am a purist I admit it is a marvelous idea.
Keep us posted if the idea moves forward.
Cheers
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
1970 280SE living 3.5 donor car
GGR
  • USA, DC, Washington
Re: engine up grade
« Reply #5 on: September 15, 2016, 12:20:23 »
I had a W111 Coupe fitted with a 6.9 M100 engine. The car was very nose heavy. This is why I went with M117 alloy blocks after that. Easier to fit, more power, similar torque, lighter and better balanced car. Keep the rear end though, you will need that ratio with a bigger engine.
JonathanB
Re: engine up grade
« Reply #6 on: October 28, 2016, 03:24:18 »
There was a prototype 6.3 Coupe but it was too ugly to replace the low grille W111.
See: http://www.germancarforum.com/threads/classic-mercedes-benz-prototypes-and-concepts-1966-1970.50932/
Re: engine up grade
« Reply #7 on: October 30, 2016, 04:27:21 »
That is some serious ugly.
