Author Topic: Gas Tank Pads?  (Read 3854 times)
Gas Tank Pads?
« on: October 31, 2004, 13:14:51 »
Has anyone removed their gas tank and replaced the pads that sit between the top of the tank and the bottom of the trunk floor?  Look at the attached picture... It shows the underside of my car, gas tank removed.  You can see some of the pads still glued to the underside, the remaining pads are still glued to the old tank.  These old pads appear to be made of cork?  What is recommended to use?  What sort of glue?  Can I buy the material in bulk and cut into squares?  Ideas are appreciated.  Local auto parts store doesnt seem to carry anything that is useable.  I would like to avoid the dealer....
Thanks!
Memphis, TN.
1997 E320
Download Attachment: underside copy.jpg
55.55 KB
« Last Edit: October 31, 2004, 17:20:31 by bpossel »
Re: Gas Tank Pads?
« Reply #1 on: November 01, 2004, 09:08:59 »
I suggest using one or more layers of the Wurth sound deadening material; it is the same stuff that is on top of certain areas of the trunk.  You can find it here:
http://www.goodspeedmotoring.com/wurth-european-sound-deadening-panels.html
Thanks to Doug Kim for the info.
« Last Edit: January 27, 2009, 18:32:21 by vanesp »
Re: Gas Tank Pads?
« Reply #2 on: November 01, 2004, 12:15:30 »
Michael,
Thanks!
That's a great idea!
Memphis, TN.
1997 E320
Re: Gas Tank Pads?
« Reply #3 on: November 02, 2004, 20:48:35 »
fyi...
The new gas tank arrived tonight.  It has the pads already glued on.  New tank does not include the bottom drain plug with screen, filter.
Memphis, TN.
1997 E320
Re: Gas Tank Pads?
« Reply #4 on: November 03, 2004, 23:12:14 »
Where did you buy from?  Was your buying experience satisfactory?
Re: Gas Tank Pads?
« Reply #5 on: November 04, 2004, 04:41:48 »
Was the tank full when it arrived ??   :D
'03 CLK Kompressor
Re: Gas Tank Pads?
« Reply #6 on: November 04, 2004, 06:42:11 »
I purchased the new gas tank from Rusty (salesman) at: http://parts.mbz.org/
Rusty was very helpful, did a search while I was on the phone with him, determined that 16 tanks were in the USA and delivery would be within a couple of days.  Rusty had the best price out of the many places that I called.  I would recommend him as a good source for your MB parts.
Memphis, TN.
1997 E320
