Author Topic: Cold start Valve........plating??  (Read 4008 times)
jan lauwers
  • Belgium, Antwerpen, Geel
« on: May 30, 2016, 09:16:47 »
Hello gentlemen,
I am having most of the parts of my engine compartment plated. What about the CSV? I presume this is not the thing to do when I see these extremely small spray nozzles. I could not figure out how to demount the nozzle... obviously only the lid should be plated. Is it Ok to take this thing apart, or is this risky business? +how to do this?
Thanks guys,
Jan
Jan Lauwers, Geel, Belgium
White 280 SL 1969
Re: Cold start Valve........plating??
« Reply #1 on: May 30, 2016, 18:20:22 »
The cold start valve housing is not plated. It should be left bare aluminum. The fuel and air line fittings can be removed and yellow cad/yellow zinc plated.
« Reply #2 on: May 30, 2016, 18:23:32 »
The solenoid can be plated too but all plated parts should be immersed in a light oil (WD40) as soon as possible after plating.
Otherwise pipes get block and moving parts like solenoids get seized.
« Reply #3 on: May 30, 2016, 18:56:01 »
I avoid plating anything like solenoids or vacuum cells because of these reasons. We use gold paint on BC units, solenoids and vacuum cells. Why take a chance? I may not be exact but most people never even notice.
« Reply #4 on: May 30, 2016, 19:44:04 »
I was nervous until I'd done a few but the process actually conditions rubber so fuel hoses come out like new!
jan lauwers
« Reply #5 on: May 31, 2016, 07:13:30 »
Thanks guys... I think I wont have it plated then... instead I should go for a paint I think.
stickandrudderman: what do you mean by: 'the process conditions rubber so fuel lines come out as new'?
Cheers,
Jan
White 280 SL 1969
« Reply #6 on: June 01, 2016, 19:01:34 »
I mean that I routinely include original fuel hoses with my yellow plate parts and they come out like new.
« Reply #7 on: June 01, 2016, 21:22:07 »
I use a spray can paint sold here in America. Dupli-color it is a match for a Chrysler color I believe. right bracket color is factory yellow cad plating and left color is the paint.
