Author Topic: Coupe  (Read 3340 times)
iftykhan
Coupe
« on: June 01, 2016, 13:23:07 »
I went to view a 280 yesterday which is a full on restoration project but is coming up as a SLC with a car check company and as a coupe on the logbook.
I know there are companies out there who can convert a californian coupe to a standard car with soft top but this vehicle looks to be an original standard car.
Has anyone else ever come across a standard car with the word "coupe" on the logbook?
Ifty
« Last Edit: June 01, 2016, 19:52:39 by iftykhan »
Re: Coupe
« Reply #1 on: June 01, 2016, 21:49:42 »
Do the serial numbers on the papers match the serial number stamped in the body on the passenger side frame rail forward of th subframe mount under the hood (http://www.sl113.org/wiki/DataCard/VIN)?  Identity tags can be switched but the frame rail stamping would be tougher to fake.  If they match it is probably just an error in the paperwork or perhaps a car delivered without a soft top but still having the compartment which also happened from time to time.  the soft top was simply bolted in later.
« Last Edit: June 01, 2016, 21:54:41 by Shvegel »
iftykhan
Re: Coupe
« Reply #2 on: June 02, 2016, 16:47:46 »
Thanks Shvegel
I will be popping back to view the car again as it was completely surrounded by storage items in the back corner of the garage.
Cheers
Ifty
relbhcb
Re: Coupe
« Reply #3 on: June 02, 2016, 17:43:20 »
The V5 for my UK spec 1964 230SL has "D.5 Body Type: Coupe".
HTH
iftykhan
Re: Coupe
« Reply #4 on: June 04, 2016, 18:11:22 »
Thanks Julian
Did the V5 state the vehicle as an SL or SLC ?
Thanks Ifty
relbhcb
Re: Coupe
« Reply #5 on: June 07, 2016, 09:31:41 »
It shows "D.3. Model ... 230 SL"
Sorry for the late reply, but only log in occasionally.
