Author Topic: Weather strip replacement for window to door (runs length of car door)  (Read 3297 times)
Pinder
  • USA, NJ, Edison
Where can I get the replacement weather strip to replace the seal that runs the length of the doors. From top of door to start of window? there is a Uro replacement body kit that has several seals but Im not sure if the one for the window is included.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Pinder, Are you referring to the window brush wisker's (1157250965) on top of the door inside and out, Or the door seals (1137200778, 1137200878) that run all the way around the bottom and sides of the doors?- They both can be had at the usual places. Both are here on page 1 of pelican parts seals listings
http://www.pelicanparts.com/catalog/SuperCat/8734/MBZ_8734_BDYSEL_pg1.htm#item4
Pinder
  • USA, NJ, Edison
thanks Tyler. it was the wiskers i was looking for
