Author Topic: coating and seals  (Read 4061 times)
jan lauwers
  • Belgium, Antwerpen, Geel
coating and seals
« on: June 09, 2016, 08:47:07 »
Hello friends,
I've had some parts of my engine powder coated (silver) and others (blacks) done by the KTL process.
I am quite happy with the result at least from the 'looks'...
Question:
Does powder coating have any effect on seals, or on liquid seals? Somehow my gut feeling tells me that it would be best if I removed the powder coating from the flanges that hold the seal. See arrows on the pic pl.
Secondly, I have been a bit over enthusiastic and I forgot to mask the inner treats. I have already tried to remove the powder with a small rotating steel brush, but that so far was not very successful. Now I am thinking of glass blasting the inner threats it in a small machine that allows for working very locally in small area's. Or perhaps I could try with taps? (not sure if they exist of these sizes).
Any wisdom here on those 2 topics please?
As always, ... thanks again guys,
Jan
Jan Lauwers, Geel, Belgium
White 280 SL 1969
cfm65@me.com
  • Cape Town, South Africa
Re: coating and seals
« Reply #1 on: June 09, 2016, 13:52:09 »
Hi Jan,
My experience is that powder coating sticks like crazy. I dont think you need to be concerned about mating surfaces. However, I would make sure they are flat, sometimes they have a little pip on, maybe a little speck of sand from the sandblasting. Might also be a little rounded at the edges.
The powder coating on the thread is another story. Sand blasting and wire brushes will not make the powder coating jump off.  Unfortunately the sand blast cleaning before the powder coating, leaves the metal quite rough, with small impact craters caused by the high speed sand during the cleaning process. The small craters and clean rough surface allows the power coating to stick like mad. Cleaning the thread will be very diffycult and may take a while.
Dont ask how I know, I have walked that road.
Good luck.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
jan lauwers
« Reply #2 on: June 09, 2016, 14:50:37 »
Thanks Chris,
Sounds like I have a little problem on my hands then. I will be a bit more patient and try harder. The blasting that I am going to do is not with sand, but with glass particles, perhaps that works better on the threads. I will do that in the workshop of a plating specialist who is kindly letting me use his machine, perhaps he has some experience with this too. I will also look if I can finds thread taps of this size.
Jan
White 280 SL 1969
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #3 on: June 09, 2016, 18:45:54 »
I powdercoated a delicate vintage motorcycle frame once and the plugs I made for the threads were accidentally removed by the kid at the powdercoating place.   The powdercoater felt bad and found me a guy locally who has some antique "thread chasing" taps in whitworth thread he leant me.  They worked a treat.
The taps were made specifically for chasing threads instead of making new ones.  Check around some old car restoration guy must have some.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
jan lauwers
« Reply #4 on: June 09, 2016, 19:10:00 »
Thanks Bonnyboy... thread chasing taps, that's what I meant to say.. but I did not know the correct english word for it... Learning all the time here..  ;D
Jan
White 280 SL 1969
« Reply #5 on: June 09, 2016, 19:51:17 »
Thread chasing taps are widely available. Don't use thread "cutting" taps
http://amzn.com/B000AEX8DW
or home depot
Re: coating and seals - paint remover
« Reply #6 on: June 09, 2016, 23:25:25 »
Quote
Jan,
Well, I had the same problem as you have with my rear axle parts before assembly. :P
Had all the "black parts" for my rear end powder coated.
The guy (professional) who was assembling the differential and the complete rear axle was extremely angry about me.
He removed (scratched off) all the coating from any sealing surface and yelled at me that the sealing wouldn't work (properly) with the powder coating.
Of course the same for any threads.
Maybe not so much of a problem for flat sealing surfaces without a lot of torque on the fixing bolts - like for the distributor drive lid on your picture. But maybe more for the oil housing.
Use paint remover (paint stripper) - works well on powder coat.  ;)
Good luck,
(European neighbor)
« Reply #7 on: June 10, 2016, 22:41:48 »
And that's why I won't use it on engine parts. In fact, I don't use it.
