Author Topic: Where does thi fit  (Read 3291 times)
AndersO
  • Sweden, Skane, Barsebäck
Where does thi fit
« on: June 09, 2016, 21:40:16 »
I took my 280 SL apart over a year ago, and now I am close to having it all together again however, I can't remember where thi piece belongs. Can anyone help?
Anders
Re: Where does this fit - oilpump splash panel
« Reply #1 on: June 09, 2016, 23:02:50 »
Hello Anders,
Yes, I do remember that part.
Thought always it was only used on the earlier M127 engines but no longer on the 129 and 130E engines. Well, I was wrong - I guess. :-X
Couldn't find this part anymore in the EPC - weird.
Perhaps a parts number no longer pictured in the EPC. I am too stupid to read Rushian. :o
mbzse
« Reply #2 on: June 09, 2016, 23:25:44 »
Quote from: 114015
.../...that part. Thought always it was only used on the earlier M127 engines but no longer on the 129 and 130E engines
You are right Achim. The anti-splash shield was dropped from assembly, early on in the M129 production (W108 250SE cars).
So not used in Pagoda 250SL and 280SL engines.
/Hans S
/Hans S
AndersO
Re: Where does thi fit
« Reply #3 on: June 10, 2016, 06:06:45 »
Many thanks, this means it must have come with the 250 sedan engine that was put into the car many years ago. Now I have replaced it with the correct 280 SL engine (about to be started for the first time after a complete renovation). Any tips or tricks on where to start adjusting if it comes to live - ignition I guess?
Many thanks again,
Anders
« Reply #4 on: June 10, 2016, 18:37:51 »
Anders,
Pls. see Joe's linkage tour !
http://www.sl113.org/forums/index.php?topic=5003.0
Good luck!
« Reply #5 on: June 11, 2016, 11:33:54 »
Remove the King lead from the coil to prevent starting then crank the engine on the starter until you get indicated oil pressure.nThen re-fit the King lead and fee her up.
