Author Topic: 280SL 1968 -- Oily spark plug  (Read 3518 times)
Thierry du Laos
« on: June 13, 2016, 05:06:23 »
I wonder when I will finish with the problems on this car!!!
Last week after adjusting perfectly the fuel pump and air flap linkagees, she was running nice.
This weekend I want to start again and she runs very bad, and ends by stoping.
I found the 1 and 2 spark plugs oily, preventing the sparks....
I suppose oil coming down from the valves.
Is it easy to fix without removing the head?
Re: 280SL 1968 -- Oily spark plug
« Reply #1 on: June 13, 2016, 05:25:38 »
Hello Thierry, are you getting some blue oil smoke from the exhaust?
Thierry du Laos
« Reply #2 on: June 14, 2016, 03:55:50 »
I didn't notice Joe. I didn't drive the car out yet, just got the injection and air flap adjusted together.
And just found that I had more troubles adjusting because had that oil on the spark plugs preventing ignition sometimes...
What I can say now is that the oil is clean clear, not burned yet.
Just discovered this weekend after the car has been sitting one week.
« Reply #3 on: June 14, 2016, 18:39:00 »
Change that plug and take your car for a short drive then pull the same plug and see how it looks.
« Reply #4 on: June 15, 2016, 05:47:56 »
Ditto with Dan.
« Reply #5 on: June 15, 2016, 20:59:49 »
Ditto again but post a picture of the plugs.
Thierry du Laos
« Reply #6 on: June 16, 2016, 04:00:07 »
I will do in September, when I come back from France with the parts missing and drive her out the garage!!!
Now I will leave her in the garage away from the rainy season...
Just started her yesterday, no problem.
Probably not enough time since this weekend, for oil to leak down?
