Author Topic: Need a New Radiator for my 1966 230SL any good suppliers ?  (Read 6436 times)
mbazinet
Hi , new member  does anyone know where i can purchase a new radiator for my 1966 230SL ?
any help very much appreciated
Ron500E
Re: Need a New Radiator for my 1966 230SL any good suppliers ?
« Reply #1 on: June 19, 2016, 07:49:59 »
I had my old one re-cored. Cost around $350.00 or so in Chicago.
Ron
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #2 on: June 19, 2016, 13:21:17 »
I just had mine re cored also at $400.  I called around and found a used one that was supposedly reconditioned and they wanted $1495.  By the way it was ADSIT that had the used radiator.  Their on line price was $1345 and when I called the price was $1495.  I had my original re-cored instead.  If you do find a used one you will probably have to get it re-cored anyway.  Make sure it is for the correct transmission in your car.  The automatic has a trans cooler.
« Last Edit: June 19, 2016, 20:23:29 by badali »
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
perry113
  • USA, NY, Rensselaer
« Reply #3 on: June 19, 2016, 15:26:46 »
I just had my radiator recored for my 1966 230SL with the correct radiator core for $500.00. That's the only way to go.
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
mbazinet
« Reply #4 on: June 19, 2016, 19:31:59 »
Thanks very much guys looks like mine has been repaired and recored a few times   probably should look to get a new "donor" core to work with    I appreciate all the help !
kampala
  • USA, CA, Beach Cities
« Reply #5 on: June 20, 2016, 04:54:01 »
Especially since you are in Maine you should visit Gernold.   He's one of the experts on these cars and has a particularly good reputation specifically for radiators.   You will read a lot more about radiators and Gernold on this forum.
Here is Gernold's website link to the radiators he supplies:  http://www.sltechw113.com/parts.html
250sl - later - manual
280sl - 1971 - Auto - LSD
« Reply #6 on: June 20, 2016, 12:04:19 »
As long as your upper and lower tanks are OK you can get it cored as many times as you like. Is there something wrong with yours?
« Reply #7 on: June 20, 2016, 13:28:55 »
I purchased a recored unit from Gernold on exchange in 2011.
Typically, when you go to a "local" radiator shop in your area, where ever that may be, the shop will use/order standardized radiator cores they purchase and solder the unit back together. That's why sometimes when you see a recored radiator on an older or import car [in the US] it doesn't always look correct.
What Gernold told me is that he found a place, I think it was in Maine, where the firm had the equipment to actually manufacture the cores--you know, bend the fins, create the tubes, etc. So, Gernold came up with the sizing and capacity specs and has the cores made for him specifically for the Pagoda radiators.
My recored unit from Gernold worked perfectly from the moment it was installed. Surely this isn't the only workable solution but those who know Gernold know he has extremely high standards.
Mechudo62
  • Mexico, Distrito Federal, Mexico City
« Reply #8 on: June 23, 2016, 23:05:36 »
The Mercedes Benz Classic Center in Irvine, Ca. last February quoted me $945.00 dollars (with MBCoA discount included) for a brand spanking new radiator for my 1970 280SL... If they still have them available I would go with a factory unit for added peace of mind...
Greetings from sunny Mexico!
Fernando Mangino
mbazinet
« Reply #9 on: July 14, 2016, 01:51:22 »
Mine has been recored a few times while the car was in Florida  it looks like the tanks have had  some rough treatment  they are dented and just don't instill a Proper quality with me.
Yes I need down to visit  Gernald  he did return my call and I am eager to meet him from what I have seen he is very well regarded. He's not to far from Bangor.
« Reply #10 on: July 14, 2016, 05:39:04 »
The radiator for a manual 230SL is also available from the parts manufacturer in Poland:
http://www.sl113.org/wiki/Suppliers/Warsaw
Scan down to the bottom of the list "nr B037": http://www.retroteile.pl/index.php?option=com_content&view=article&id=12&Itemid=9&lang=pl
UJJ
  • USA, CA, Grass Valley
« Reply #11 on: July 14, 2016, 11:14:23 »
Agree with Michael, Gernold is the best way to go (not only in radiators)
Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
