Author Topic: sunroof (felt) whiskers on a w111 coupe fit question  (Read 4636 times)
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« on: June 22, 2016, 18:21:42 »
I am having a issue with installing sunroof wiskers on a w111 coupe.  A friend of mine has three 3.5 coupes all w111 and we removed the sunroof felt (whiskers) from one of them.  We got the replacement part with a w115 number on it but it won't fit and looks too big, We checked on the other coupes but the felt is so old it is beaten down and I can't tell if it was ever bigger.  We have the clips as far back as they will go.  IS THERE A DIFFERENT PART NUMBER FOR THE SUNROOF W111 COUPE 67-71 sunroofs?
Thanks, Bob
« Last Edit: June 22, 2016, 19:07:19 by BaronYoungman »
Bob "Baron" Youngman
1965 220se coupe restomod
Re: sunroof (felt) whiskers on a w111 coupe fit question
« Reply #1 on: June 22, 2016, 22:05:59 »
I think that 115 part number is for regular bristle rail that you would find on a 113 door glass application. 111 coupe sunroof seal is smaller and not as thick. I'll fairly confident it's not the same part.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #2 on: June 23, 2016, 16:41:13 »
thanks, yep you are correct  found part #110 782 05 24 and 110 782 06 24 so if someone has question in the future.
Thanks you
