Author Topic: Fuel injection pump idle adjustment knob - starting point HELP  (Read 4339 times)
mbazinet
i have been trying to get get a decent idle idle out of my 66" 230SL, but in doing so I feel I may have gone too far, I have been turning the idle adjustment knob on the backside of the FI pump but now I feel I have gone way out of the original spec.  Does anyone know what the starting point should be for this adjusting screw? (IE x number of clicks from a fully bottomed position)  Any help is greatly appreciated.
Re: Fuel injection pump idle adjustment knob - starting point HELP
« Reply #1 on: July 04, 2016, 06:02:45 »
Do the split linkage test during idle.
« Reply #2 on: July 04, 2016, 17:32:00 »
There is no "starting point" per se. Every car is set up slightly different. As Joe suggested do a split linkage test to confirm if you are running lean or rich. Then go and adjust your FIP idle knob and air screw accordingly. Make sure the engine is at operating temp otherwise you will be countering the WRD (warm running device).
mbazinet
« Reply #3 on: July 04, 2016, 17:35:36 »
Thanks very much for the info.     I will give that a try       do either of you know what the ignition timing should be at idle ?
« Reply #4 on: July 05, 2016, 00:17:32 »
Idle timing depends on the distributor in your car. Post the Bosch #.  Otherwise make sure the vacuum cell on the dist. is working and set the timing at 3,000 rpms. at 30degrees BTDC.  Most of us like to go up to 35-38 degrees BTDC depending on the fuel octane.
mbazinet
« Reply #5 on: July 07, 2016, 01:40:59 »
I checked the distributor its a # 51 Bosch
« Reply #6 on: July 07, 2016, 02:45:32 »
I run my 051 distributer in my 250 at 35 deg advance. Had it set at 38 briefly and would get an occasional ping. Every car is a bit different in what it can handle. Be sure to use 91 octane.
mbazinet
« Reply #7 on: July 07, 2016, 18:31:24 »
Setting the timing with vacuum attached ? or disconnected ?  Please advise
« Reply #8 on: July 07, 2016, 20:18:29 »
On the 051 leave it connected while setting the timing above 3000 rpm's. It is a vacuum retard system that only functions at idle.
mbazinet
« Reply #9 on: July 14, 2016, 01:45:24 »
Thank you I will give that a try
