Author Topic: Cursors broken - reproduced  (Read 2460 times)
swood1
« on: July 14, 2016, 06:53:08 »
Hi all,
On re-assembly of my car I noticed the cursors on two of the dials are broken for the temperature adjusters.  Just wondering if you can buy just the cursor instead of the whole assembly?  If I have to get the whole assembly I may as well get the full set.
Regards
Steven
Re: Cursors broken - reproduced
« Reply #1 on: July 14, 2016, 16:58:54 »
If you are referring to the temp and position levers (4) yes they can be bought individually. However you may want to replace all 4 because if 2 are broken then the other 2 are not far behind. Saves you from having to go back in a second time.
If you are refering to the arrows and the red and blue blend identifiers, yes they are available.
Both available on this link:
http://www.sls-hh-shop.de/230-280SL-R113/83-Heizung/?_artperpage=10&listorderby=oxstock&listorder=desc
swood1
« Reply #2 on: July 15, 2016, 08:23:54 »
Thankyou,
I shall just buy a full set.
Steve
