Author Topic: 1966 Mercedes 230SL power steering shaft  (Read 7516 times)
Henry52
  • Singapore, Central Singapore, Singapore
« on: July 18, 2016, 05:39:34 »
Hi All
I am trying to upgrade my manual steering to power steering but found my current steering shaft is a little too long. Does anyone happen to know the exact length of the lower power steering shaft and where can I buy one? My current steering shaft comprises two shafts joined by a universal joint.
Henry
hkollan
  • Spain, Castilla-La Mancha
Re: 1966 Mercedes 230SL power steering shaft
« Reply #1 on: July 18, 2016, 14:57:24 »
Hans K, Cuenca, Spain
« Reply #2 on: July 18, 2016, 16:27:18 »
Henry,
you will also need a different Pitman arm!
I bought the arm and the shorter spindle from ai-Motors and both fit perfectly.
« Reply #3 on: July 18, 2016, 18:53:05 »
Or you can just modify what you have. (At least, here in the UK you can legally do it).
« Reply #4 on: July 18, 2016, 20:02:28 »
Stick,
how do you modify the Pitman elbow and arm length?
Compare the mechanical and power steering Pitman arms ID #121 and ID #216!
