Author Topic: new coil springs  (Read 2605 times)
winston the browndog
new coil springs
« on: July 21, 2016, 01:51:19 »
Who makes  and what are the  best coil springs  for a 69 280sl ? I need fronts and rears . I am running alloy factory wheels , with Bilstein shocks , More interested in a nice ride than anything else . Thanks ,Paul
RonB
  • USA, MN, Cottage Grove
Re: new coil springs
« Reply #1 on: August 05, 2016, 03:18:43 »
Hi Paul,
Try Kansas City Wire for your spring.l They make all kinds of spring for the auto and truck industry.
 I have them - perfect - did 20% stiff than factory. I should have  get the progressive in the front - little less dip on braking. Doing 20% is not to stiff.
By the way, this is where John Olson orders his custom springs from and they approximately they 20% stiffer.
If you have a problem with finding KCW number - I do have it at work. By the way I believe the cost was around $375 - $400 for the set of 4. I also did my compensating spring at the same time.
RON
Previously FULL Member twice with over 500 post
71 280SL - SOLD on BAT
97 E420      SOLD
85 300D      SOLD
85 R107 380SL
07 Volvo S60
Doug McAllister
  • USA, CA, San Ramon
« Reply #2 on: January 30, 2017, 00:21:50 »
Hi Ron
I am interested in ordering 20% stiffer springs from Kansas city wire. Have a quote for stock but wanted to go stiffer (linear).
Before I call them, I wanted to know how you specified what you wanted.
I know I want approx. 300 lbs./inch (vs. about 250 lbs/in. for stock) my real questions is how much shorter did you specify since a stiffer spring requires a shorter free height to get the same loaded height. I have seen other comments that 3/4 of an inch is about right.
Doug
Doug M
1969 280SL MB
1988 928S4 Porsche
2014 Audi A5
