Author Topic: 280sl restoration  (Read 57652 times)
guyke
  • Belgium, Flanders, Hasselt
Re: 280sl restoration
« Reply #125 on: January 09, 2017, 08:53:36 »
the 10 of januar there is a guy comming inspecting my water tubes in my house , i had a leak and repaired it , its a company that is send by the insurance to inspect everything to prevent future leaks , i think that includes my pagoda  8) 8) 8) 8) 8) ;D ;D ;D ;D ;D prevent future rust  ;D ;D
thanks for showing us the product , on the /8 mercedes we always pouring a mix from rust preventer and used oil in the cavitys , leave that some weaks in it , and finaly let it out , cavity treathing on high level  ;D ;D
« Reply #126 on: January 12, 2017, 16:27:49 »
You've really made huge progress in 6 months!
Joel
« Reply #127 on: January 13, 2017, 19:21:01 »
Thank you,
in about 2 weeks its 1 year sincs I started the work.
This week I got it of the frame and in the rotisserie.
And have taken off the last undercoating.
Joel
« Reply #128 on: January 17, 2017, 16:34:20 »
left rear is in
Joel
« Reply #129 on: January 17, 2017, 16:40:29 »
right front Reinforcement Under floor is damaged so cut it out, made it straight and welded back in.
Joel
« Reply #130 on: January 17, 2017, 16:42:50 »
and the new right front floor pan in.
guyke
« Reply #131 on: January 17, 2017, 18:43:01 »
one word
respect
Joel
« Reply #132 on: January 20, 2017, 19:08:51 »
Today borrowed an enclosed trailer to go sandblast the underside and last spots.
Joel
« Reply #133 on: January 20, 2017, 19:40:20 »
Joel
« Reply #134 on: January 27, 2017, 18:57:05 »
Now that the Inside of the crossmember is sandblasted I applied primer and welded the floor section in.
Joel
« Reply #135 on: January 27, 2017, 19:00:33 »
I have coated and welded the frame rails closed.
Joel
« Reply #136 on: January 27, 2017, 19:04:19 »
some lead done on the 4 wings. I have not exaggerated because I think this is very unhealthy work. just a little on the welds.
Joel
« Reply #137 on: January 27, 2017, 19:08:45 »
I have the trunk floor not yet in so I could primer the Inside of the fenders en the upper panel good.
Joel
« Reply #138 on: January 27, 2017, 19:14:43 »
1 coat of black époxy and 1 coat white of primer
Joel
« Reply #139 on: January 27, 2017, 19:17:22 »
let it cure for 2 days
Joel
« Reply #140 on: January 27, 2017, 19:19:44 »
trunk floor in and some époxy with the brush.
neelyrc
  • USA, AL, Birmingham
« Reply #141 on: January 28, 2017, 01:58:38 »
Really fantastic work Joel!!
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
Joel
« Reply #142 on: February 07, 2017, 16:54:06 »
2 coats of black hs primer filler in the tunk and convertible top space.
Joel
« Reply #143 on: February 07, 2017, 17:02:47 »
some spray filler on the places I've put lead.
Joel
« Reply #144 on: February 07, 2017, 17:05:42 »
taping of the outside
Joel
« Reply #145 on: February 07, 2017, 17:07:23 »
seam sealer
Joel
« Reply #146 on: February 07, 2017, 17:11:26 »
stone guard
Joel
« Reply #147 on: February 07, 2017, 17:15:59 »
DB 181 hellbeige and 2 coats clear
Joel
« Reply #148 on: February 07, 2017, 17:26:57 »
done
Joel
« Reply #149 on: February 07, 2017, 17:32:28 »
