Author Topic: 70 280SL door panel removal  (Read 2860 times)
CJHenderson
  • USA, AR, Benton
« on: July 30, 2016, 15:37:19 »
Can not get the door panel off due to the door handle release lever. Do I need to remove the plastic insert behind the handle or do I need to jiggle the panel to remove?
1950 MG-TD
mbzse
Re: 70 280SL door panel removal
« Reply #1 on: July 30, 2016, 15:42:44 »
Small cross head screw under black thin plastic cover, lift cover carefully in corner
/hans s
/Hans S
CJHenderson
  • USA, AR, Benton
« Reply #2 on: July 30, 2016, 15:45:25 »
Thank you
1950 MG-TD
