Please check out joining the
Emergency Contact List
for help during your travels!
Body, interior, paint, chrome, and cosmetic items
Removing window spring
Topic: Removing window spring (Read 2911 times)
CJHenderson
Full Member
Silver
USA, AR, Benton
August 07, 2016, 20:03:04 »
How do I remove window spring? Window is fully retracted but spring has a lot of tension
1950 MG-TD
Full Member
Platinum
USA, CA, Fallbrook
Re: Removing window spring
August 07, 2016, 20:15:59 »
I've done this auccessfully by holding the end tightly with pliers (I think vicegrips) and using some muscle stretching the spring enough to get it past the catch and off.
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #2 on:
August 07, 2016, 20:22:25 »
Ok thanks I'll give it a try
1950 MG-TD
Full Member
Platinum
USA, CA, Solana Beach
Reply #3 on:
August 07, 2016, 21:16:10 »
Is the window lifter still in the door?
It is easier to remove the spring when the lifter is out.
1966 230SL automatic 334G light blue (
sold
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #4 on:
August 17, 2016, 02:13:38 »
It's out thanks
1950 MG-TD
Pinder
Full Member
Platinum
USA, NJ, Edison
Reply #5 on:
August 17, 2016, 02:37:45 »
I've used sheet rock screws to safely remove the springs on my soft top frame. basically screw them in to each thread section until spring expands then it should be easier to remove it. you may need 10 or 20 screws to stretch it.
1970 280 SL Light Ivory DB 670. 4 Speed manual shift no AC Limited Slip Diff.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
