Author Topic: Revs increase when brake pedal applied...  (Read 4976 times)
Neil Thompson
« on: August 21, 2016, 20:11:37 »
... then stalls when gear selected.
230SL Auto with PAS, restored car thats been stood with poor fuel, see my other post re elec fuel pump.
I've cleaned all the fuel lines, set the points, adjusted the ignition timing and also adjusted the linkages/venturi as per the basic linkage tour on the forum. The car runs well and idles ok at around 800rpm. If I press the brake pedal the revs rise to around 1,300rpm, if i then put it into gear it stalls. There are some things in the tech manual I haven't tried to test yet such as the WRD and the CSV as I've ran out of daylight but I thought I would just throw my problem out to the experts hoping for a quick fix. Could the mixture just be too rich on tickover or could the servo be dodgy?
as always, any help welcomed
Regards Neil
1957 190 SL RHD DB180 Silver
Re: Revs increase when brake pedal applied...
« Reply #1 on: August 21, 2016, 20:33:05 »
The search function is feeling hurt that you are ignoring it!
Neil Thompson
« Reply #2 on: August 21, 2016, 21:32:31 »
I've searched Colin, but sometimes it's good to talk!
Neil
dpreston Virginia
  • USA, VA, Salem
« Reply #3 on: August 21, 2016, 21:39:45 »
Sounds to me like a bad brake booster.,
190SL 1960 Sold
280SL 1969
280SE 1969 cabriolet
Vette 67
Porsche 912 67
ejboyd5
  • Southold, NY
« Reply #4 on: August 21, 2016, 22:20:59 »
Plug the vacuum connection to  the brake booster to see if the problem goes away.
rgafitanu@gmail.com
« Reply #5 on: August 22, 2016, 17:22:21 »
I had the same thing,it is a leak in the brake booster. Take it to NAPA, they will rebuild it for about $100. Anything else on the internet and ebay is very expensive.
Radu
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #6 on: August 22, 2016, 22:04:00 »
Colin is right ... Look at the search results
Here ----> http://www.sl113.org/forums/index.php?action=search2
Let us know how you made out, not just for us also for others that will use the search in future years.
Dieter
« Reply #7 on: August 22, 2016, 23:23:37 »
Radu
Good advice, except TS is located in UK where NAPA may not exist ...
Pinder
  • USA, NJ, Edison
« Reply #8 on: August 23, 2016, 12:58:41 »
I had the same issue. Was brake booster. I got mine from Rockauto. If Napa rebuilds original that would be a good option. Rockauto was pretty cheap at around 100 with core refund.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
« Reply #9 on: September 17, 2016, 07:35:08 »
Just a voice here and if you find it contrary to forum's wisdom, please ignore it.
I had the same thing - revs changed as the brake pedal was pressed. Before a major booster overhaul I replaced a simple oring between the booster and brake master cylinder. The symptoms are gone. Revs do not change.
I was reading Haynes and I spotted a sentence that this oring needs to be "vacuum tight" and needs to be renewed while working on booster. So I did that.
