Become a
Full Member
Emergency Contact List
General Discussion
Under dash panels
Topic: Under dash panels (Read 3171 times)
john.mancini
Full Member
Gold
USA, FL, Nokomis
Under dash panels
August 22, 2016, 13:29:43 »
Has anyone replaced the foam backing on their under dash panels? My panels are in perfect condition but the foam backing has dried out and is disintegrating. I see that Authentic Classic sells repro panels but I would like to keep the originals. Any tips?
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
Ulf
Associate Member
Gold
Denmark, Fredericksberg, Rungsted Kyst
Re: Under dash panels
August 31, 2016, 07:31:06 »
I'm pretty sure that it would be an easy DIY project with some similar foam (or perhaps even a bit heavier like the thin sleeping pads used when camping) cut to size and glued onto the pieces with a decent spray adhesive like 3M :-)
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
Tyler S
Inactive
Platinum
USA, CA, Encinitas
Reply #2 on:
August 31, 2016, 15:26:57 »
Authentic Classics also sells just the foam in bulk size. He has 2 thicknesses. Genune MB part. Use spray adhesive to attach then trim with exacto knife.
john.mancini
Full Member
Gold
USA, FL, Nokomis
Reply #3 on:
September 03, 2016, 20:39:45 »
Thanks for the info. I finally did check the Technical Manual and there were some previous posts regarding the under dash panels. Aside from the foam, my panels are perfect so I will check out the foam from Authentic Classics. Thanks again.
98 911 cab
56 Ford F100
23 Z4M40i
General Discussion
Under dash panels
