Author Topic: Speedo and Tach Needles Bouncing at Low Speeds or Idle  (Read 2667 times)
indy_nate8
« on: September 01, 2016, 16:13:19 »
Have a 1971 280SL, the tach and speedo are bouncing at idle or lower speeds then are smoother as I increase speeds. Any suggestions before I replace the cables?
Pinder
  • USA, NJ, Edison
Re: Speedo and Tach Needles Bouncing at Low Speeds or Idle
« Reply #1 on: September 01, 2016, 17:41:58 »
try WD40 squirted down the cables
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
mmizesko
  • USA, OH, New Albany
« Reply #2 on: September 04, 2016, 22:17:11 »
Lube and cables didn't really help.  I sent my tach and speedo to speedometer.com and the needles smoothed out.  Does your tach "howl" when it gets below 45 degrees?
1970 280SL 291H Dark Olive
