Author Topic: alternator mounting  (Read 6648 times)
gnj588d
alternator mounting
« on: September 04, 2016, 18:38:43 »
Have adjusted the alternator belt on my 230 and tightend the relevent nuts/bolts but when I pinch the belt to check the
tension the alternator seems to move as if rubber mounted ? is this normal.Thanks.Mike.
Re: alternator mounting
« Reply #1 on: September 04, 2016, 19:01:41 »
It should not move. Double check the bracket bolts where the bracket bolts to the block. Also check the bolt at the end of the threaded rod where it bolts to the block near the balancer. Make sure the lower pivot bolt is tight as well.
gnj588d
« Reply #2 on: September 05, 2016, 14:21:17 »
Thanks will check it out this weekend.Mike
gnj588d
« Reply #3 on: September 05, 2016, 22:07:13 »
Just found the alternator bracket is brocken,looks quite awkward to remove any tips would be appreciated
 I have the part number 127 150 0673 wonder if its still available.Thanks.Mike
« Reply #4 on: September 06, 2016, 16:42:05 »
Mike, Assuming you don't have AC then removing the bracket it pretty straight foreward. Remove the alternator then the bolts for the bracket. Easiest to do from underneath the car. Remove the Horn and bracket, will give you loads of room.
Jack Jones
  • Canada, ON, Milton
« Reply #5 on: September 06, 2016, 17:01:01 »
Hey Mike,
The bracket is available and the MSRP from Mercedes is $165.00. Many dealers on the internet will give you from 20-40% off MSRP so check them out. One link included below and there are others.
https://mercedespartscenter.com/parts/index.cfm?make=Mercedes-Benz&year=&searchText=1271500673&action=oePartSearch&siteid=215720
Jack
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
« Reply #6 on: September 07, 2016, 13:08:48 »
The later brackets were heavy cast iron and were much better than the early fabricated steel "strap" type.  You have to intstall longer mounting studs on the block if you change to the latter cast iron bracket. Be sure to seal the threads of the mounting studs or you will have an oil leak.
gnj588d
« Reply #7 on: September 07, 2016, 18:59:21 »
Thanks for the help made the job a lot easier specially taking the horn off.Cheers.Mike
gnj588d
« Reply #8 on: September 09, 2016, 19:46:38 »
  I am putting  the alternator back on after getting the broken bracket welded, the problem is I cannot remember
  the order/ position of the rubber washers ,spacers sleeves,or spacer bushing should go,cannot fin anything relevent
  on the forum,thaught I was doing well till then :-[ Cheers .Mike
gnj588d
« Reply #9 on: September 10, 2016, 12:22:55 »
Update. I have sorted everything except the spacer bushing (12mm long) just doesnt seem any room for it
 Part number 127 155 00 50.Cheers.Mike.
« Reply #10 on: September 14, 2016, 05:47:39 »
Seems like that may be the spacer that goes inside the rubber bushings.
gnj588d
« Reply #11 on: September 15, 2016, 11:06:07 »
Thanks Jo.yes got it sorted,everything in the right order trouble is the water pump pully and alternator pully
dont line up perfectly alternator pully is about 3mm out is this acceptable.cheers .Mike.
« Reply #12 on: September 15, 2016, 18:15:08 »
Hi, Mike,
That spare spacer that you have (127 155 0050, #34) is used to align the alternator to the w/p and crank pulley.
It was many years ago that I had the alternator out on the 230, so I can't remember exactly where it goes. The picture may help.
The 2 sleeves that go with the 4 rubber mounting bushes (#35) have a smaller OD
The belt 000 997 59 92 is AV10x875La
« Last Edit: September 15, 2016, 18:47:09 by Naj »
gnj588d
« Reply #13 on: September 15, 2016, 20:02:19 »
Hi Naj everything is in the right order including new rubbers. Spacer, cup, washers, and sleeves are all good.
alterator needs to move 3mm forward :( Cheers.Mike.
gnj588d
« Reply #14 on: September 15, 2016, 21:22:59 »
Naj.Just to let you know I have sorted the problem,slackened the bottom pivot bolt a few turns(must have over tightened it)
and know the pullys are perfectly lined up fitted new lock nut.Take Care.Mike
