Author Topic: Mallory fuel pump?  (Read 4248 times)
JonathanB
Mallory fuel pump?
« on: September 22, 2016, 06:29:08 »
Has anyone replaced the fuel pump on a 3.5 with a Mallory or similar non-OEM fuel pump?
perry113
  • USA, NY, Rensselaer
Re: Mallory fuel pump?
« Reply #1 on: September 25, 2016, 01:24:58 »
Why bother using a Mallory when you can buy the correct fuel pump for less for under $200.00. I would stick to what is original.
I believe this is the right pump part # 0010917101 for your 3.5 Correct me if I'm wrong. see:
http://www.ebay.com/itm/New-Bosch-Fuel-Pump-Gas-001-091-71-01-/361712667276?hash=item5437c14a8c:g:pycAAOSw-kdXys0F&vxp=mtr
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
« Reply #2 on: September 25, 2016, 03:38:21 »
You need something that will produce about 35 - 40 PSI. This system runs at 2.1 bar ( 29 PSI ) so you want a pump that's capable of running higher than your line pressure.
