Author Topic: Early 220SEB fuel injection linkage adjustment  (Read 3144 times)
perry113
  • USA, NY, Rensselaer
« on: September 24, 2016, 20:40:35 »
Does the fuel injection linkage rod from the control rod to injection pump on the early style intake manifold on a 220SEB supposed to be 233 mm in length like a 230SL or do you base the length of the venture rod by centering the position of the control rod to the hole cast into the intake manifold?
Just trying to do the final sort out on my 63 220SEB
Many Thanks
« Last Edit: September 25, 2016, 00:28:58 by perry113 »
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
Re: Early 220SEB fuel injection linkage adjustment
« Reply #1 on: September 25, 2016, 03:41:27 »
It may be the same but I would start with the alignment hole on the intake manifold. Do you have the straight pipes on your intake manifold?
perry113
« Reply #2 on: September 25, 2016, 12:30:42 »
Yes I believe so. The Intake manifold is the earlier style that is longer and taller.
Peter Perry
1970 911T Bahia Red
« Reply #3 on: September 27, 2016, 04:31:57 »
Go with the casting hole if that's case. It's better than guessing at any rate.
