Author Topic: Alternator Bracket  (Read 3131 times)
col320ce
Alternator Bracket
« on: September 28, 2016, 13:14:48 »
I've changed the alternator and the new one is a little different to the one that I took off (I think the replacement is 'more' correct for the car).  It is not sitting well on the bracket and is causing a squeak (it's slightly twisted and not exactly in line with the water pump pully. Can anyone show me what the bracket attachment should look like?  My cobbled set up can be seen in the picture ...
Thanks for any help...
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
cfm65@me.com
  • Cape Town, South Africa
Re: Alternator Bracket
« Reply #1 on: September 28, 2016, 16:39:16 »
Hi Col,
The three pullies must line up 100% or as close as you can get it. Otherwise it will damage the fan belt, possibly damage the water pump and/or  alternator bearings or, least of all, the belt will squeal lke a stuffed pig.
Although we know exactly what you are talking about, your picture does not show us the problem clearly.  Try to shim it, fore or aft, with a washer or two.  See if you could get us a better photo of the alt, the belt and the water pump, showing how they line up.
Regards
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
travellerdogs
  • Canada, British Columbia, Bowser
« Reply #2 on: September 28, 2016, 18:51:50 »
hi, I am in the process of acquiring a 65 230sl for parting out. Should have it delivered in a couple weeks. May be able to help you. thanks, Carey
travellerdogs 1969 280SL,  1981 380SL:  1955 HD Panhead: 2007 HD Street Glide: 1956 Mercury Montclair, Black 2 Dr Htp; 1965 230SL: 2005 Pontiac Sunfire: 1993 Range Rover: 1977 450SL parts car:
« Reply #3 on: September 29, 2016, 03:53:55 »
I think those early cars use a mounting kit similar to what 190SL's use. Steel bushings, rubber grommets and thin steel washers plus a ground cable.
 If you don't have the right parts in there it won't hang properly. You should also check the bracket for wear at the mounting holes. If they're out of round it won't help at all.
col320ce
« Reply #4 on: September 29, 2016, 07:43:18 »
It's pretty subtle and I don't think the photos do a good job of illustrating the problem...  But these are the photos I have.  I'll have a play tomorrow...  I think the tensioner arm may be slightly in the wrong spot.
Col
1964 230SL
1965 250SE coupe
col320ce
« Reply #5 on: September 30, 2016, 11:39:48 »
Sorted it today... I used a straight edge on the front of the pullies and added washers until it was perfect.  Not an original set-up but works fine. I'll hunt down the correct parts at some point.
Thanks as always....
Col
1964 230SL
1965 250SE coupe
