Author Topic: 230SL Contacts  (Read 5397 times)
col320ce
230SL Contacts
« on: October 08, 2016, 12:56:44 »
Does anyone know at what vin number the contacts changed from Bosch GB504 to GB543?  All I have is 1964 should have GB504 and 1965 on-wards have GB543 but I'd like to be a little more accurate.
Thanks for any help...
GB504 analogues:
1 237 013 007
01003
000 158 07 90  (MB)
GB543 analogues:
1 237 013 027
01007
000 158 20 90  (MB)
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
Re: 230SL Contacts
« Reply #1 on: October 08, 2016, 19:32:01 »
I think there are three different distributors used on a 230SL. The first two are VA and the last, the 051, is a VR unit. You should have a VA for that year of car. If you are not sure look at your distributor. VA units have the vacuum advance cell pointing towards the firewall and VR points towards the rad.
col320ce
Re: 230SL Contacts
« Reply #2 on: October 09, 2016, 06:33:47 »
Looks like I have a VR...  051...
Col
1964 230SL
1965 250SE coupe
col320ce
Re: 230SL Contacts
« Reply #3 on: October 11, 2016, 00:41:16 »
Thanks for your help Dr B
Does this mean I use the GB543 in my car?
I've attached a photo of my distributor.
Thanks again
Col
1964 230SL
1965 250SE coupe
col320ce
Re: 230SL Contacts
« Reply #4 on: October 21, 2016, 11:44:20 »
So it looks as though I have a later distributor on my car ... is this likely to cause any problems?
Col
1964 230SL
1965 250SE coupe
Re: 230SL Contacts
« Reply #5 on: October 21, 2016, 19:53:00 »
GB543 is the correct set for the 051 distributor.
You need to ensure you have the correct vacuum retard throttle body to go with this distributor.
See the wiki under distributor for details.
