Author Topic: Injector Pump Cold Start Solenoid Cleaning  (Read 3553 times)
col320ce
« on: October 08, 2016, 23:23:53 »
Can I remove the Injector pump cold start solenoid to check that the solenoid is not seized etc?  Otherwise I am a little confused on how to test it.
Thanks ...
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
wjsvb ✝︎
  • USA, VA, Virginia Beach
Re: Injector Pump Cold Start Solenoid Cleaning
« Reply #1 on: October 09, 2016, 01:43:34 »
No need to remove it: with the engine off, touch a hot 12v positive lead to the lead on the CSV solenoid and then a 12v negative to a ground on the engine.  If the solenoid is OK, you will hear it click.
OOPS! I didn't see the picture, and assumed you were talking about the CSV.  The same test may work on the IP solenoid but I can't be sure.  Sorry!
jon
67 250SL early
12 Jeep GC (gone but not missed)
69 300SEL 6.3 Euro project (gone but not forgotten)
81 280SL Euro 4spd
col320ce
« Reply #2 on: October 09, 2016, 06:22:20 »
Well that seems to work!
Both solenoids make a sound with 12v on them.
Col
1964 230SL
1965 250SE coupe
« Reply #3 on: October 12, 2016, 06:15:46 »
Now check to see if it is activated during starting.
col320ce
« Reply #4 on: October 12, 2016, 06:32:51 »
Hi joe
I'm pretty sure my thermo time switch is broken.  I've bench tested it and W is an open circuit no matter what the temp is.
I'll put it back in and put a test lamp on it. I think I am only going to get voltage to the injector solenoid for 1 second... as I think this is how the relay works when the TTS is broken.
I'll report back on a tick...
Thanks for your help...
Col
1964 230SL
1965 250SE coupe
col320ce
« Reply #5 on: October 13, 2016, 11:41:10 »
The injector solenoid gets 1 second of power then nothing...  So I need to pony up the cash for a TTS I think.
Col
1964 230SL
1965 250SE coupe
