Author Topic: Diff leak  (Read 2810 times)
col320ce
Diff leak
« on: October 20, 2016, 11:57:09 »
I have a diff leak that only occurs when the car is on all 4 wheels but not when it is on a hoist.
My mechanic says it's coming from "here" area in the picture and said it was a seal but I can't work out what the correct part is.
The rear axle number is the same as is on the data card. '64 230SL
Can anyone help with a part number?
Thanks ...
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Re: Diff leak
« Reply #1 on: October 20, 2016, 16:41:48 »
There is a boot and two clamps that hold it on. On some of those clamps, one ( can't remember which ) isn't made right and it won't tighten up properly. It's possible to fix that problem by looking at how it's made and making adjustments to the overall length.
Aside from a loose clamp or a crack in the boot, the only other thing you might find is a broken diff housing caused by not having the axle tube supported when changing the right side shock. The axle tube can drop with enough force that it will knock a chunk of cast iron out of the bottom of the housing. Since the boot and clamp covers this area it's easy to assume that the boot is leaking. Maybe not what you want to hear but you should look for this.
The cure is as bad as the problem. Axle would have to be removed and taken apart. It is possible to have it welded but it's a lot of work to get there. Hopefully, only the clamp or boot is faulty.
col320ce
Re: Diff leak
« Reply #2 on: October 21, 2016, 11:47:56 »
Thanks for a great answer.  I'll get under the car ans see whats happening with the boot.  Hopefully it will be easy ... but I doubt it.
Col
1964 230SL
1965 250SE coupe
