Author Topic: Matching Numbers for my Pagoda 280  (Read 3221 times)
DELAKOUR
« on: November 01, 2016, 14:09:46 »
Hello everybody,
Can you please help me answer on the matching number question of my car?
VIN#: 113044 12 002345 and
Engine#: 130983 12 001443.
Thank you in advance,
Antony
Re: Matching Numbers for my Pagoda 280
« Reply #1 on: November 01, 2016, 15:34:47 »
Hello Antony,
Sounds good,
could very well be a set of "matching numbers." 8)
However,
nobody here can tell you that for sure. ???
You need to have the data card (= "factory birth certificate") of your car to confirm.
You can obtain the built sheet/data card from the MB Classic Center.
Google a bit around on this site how others requested this data card.
Good luck,
DELAKOUR
« Reply #2 on: November 01, 2016, 15:53:27 »
Thank you very much Achim!
Pinder
  • USA, NJ, Edison
« Reply #3 on: November 01, 2016, 16:44:11 »
while you wait to check if the engine is the original engine, you can check to see if the hood is original and other body panels. they have a number that should match 5 digits on the chassis plate that is under the hood on the fender.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #4 on: November 01, 2016, 17:42:49 »
Hi Antony,
I see you found the right spot to post your question. As I mentioned in my e-mail to you this is the best way to get help.
Contact Tom by e-mail see his contact info below. You need to send him a copy of ownership before he can send you the Data Card that should then show both the VIN and Motor No's
Tom Hanson
Supervisor, Parts Sales
Mercedes-Benz Classic Center USA
949 598-4842 direct
thomas.hanson@mbusa.com
Good Luck
Dieter
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #5 on: November 01, 2016, 18:27:22 »
Achim,
You could have said:
"could very well be a set of "matching numbers" if your car is a 280 SL with an automatic trans" !!  ;D
Mark  8)
1998 BMW M-Rdstr Estoril Blue
