Author Topic: Fuel Problem  (Read 3677 times)
gong17
Fuel Problem
« on: November 03, 2016, 01:49:54 »
hi, have a 230SL Pagoda running 98 Octane. just in the last 3 months when the fuel reaches a level in the tank of roughly 60%, it starts coughing and spluttering, stalling etc until the tank is filled again and then it operates as per normal.
any thoughts
thanks  8)
Re: Fuel Problem
« Reply #1 on: November 03, 2016, 05:53:57 »
Welcome to the forum. It may have something to do with the quality of fuel where you live  ;). If you do a search, I think you will find the likely cause is dirt in the fuel tank.
« Last Edit: November 03, 2016, 06:18:07 by Cees Klumper »
rgafitanu@gmail.com
Re: Fuel Problem
« Reply #2 on: November 03, 2016, 12:07:30 »
If you do a search for "flower pot" in this forum you will find the most likely culprit. There are a lot of posts with this problem.
Radu
gong17
Re: Fuel Problem
« Reply #3 on: November 03, 2016, 21:23:02 »
Many thanks for your suggestions, had printed out all the fuel tank information complete with pictures and saw the "flower pot".
Will get onto that and see if it resolves the issue
Cheers
Gordon
Pinder
  • USA, NJ, Edison
Re: Fuel Problem
« Reply #4 on: November 04, 2016, 15:52:32 »
there is a small hole at the bottom of the flower pot below one of the lines. it is likely that hole is blocked as when the fuel level falls below the pot the fuel in the rest of the tank is not flowing through the hole into the flower pot which is what the fuel line draws from. you may be able to get at it by taking out the fuel level sender unit and using wires etc to clear out the hole.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Re: Fuel Problem
« Reply #5 on: November 05, 2016, 01:02:39 »
The hole in the '' flower pot* '' is more than just a hole as there is a baffle and channel on the inside edge of the flower pot wall where the fuel has to flow through. If there is crud in this channel you may not get any fuel to enter. I've been there before - maybe you will too......
 * The term '' flower pot '' is used with permission of the Benz Dr.
1988 560SEC
gong17
Re: Fuel Problem
« Reply #6 on: November 16, 2016, 21:31:07 »
Thank you to all who made suggestions on this issue, it is now all resolved after removing the tank, full drain and clean, clearing all internal pipes and most importantly removing all the crud, silt and multitude of sins from the tank. hopefully it may be ok for the next 51 years  :D and for whoever enjoys it after us
