Author Topic: Motor & Transmission Mount Replacement- will this affect Drive Shaft Alignment?  (Read 5569 times)
Mike K
  • South Africa, Gauteng, Johannesburg
    • Mike Kirkinis
This winter I plan to replace the 2 motor mounts and the transmission mount on my 280SL. While I'm at it, I'll also replace the sub frame mounts. Having done research and read up on the topic on this Forum, I feel confident enough to tackle this job.
In shopping around for the parts on the SLS website I came across the diagram below, my German's not good enough to understand this fully. Does it relate to the spacers which come with the kit and the effect they have on the drive shaft alignment?
What do I need to be aware of in replacing the motor and transmission mounts in terms of engine alignment and is there a danger of throwing the drive shaft out of sync?
All advice and input will be greatly appreciated.
Thanks and best,
Mike
« Last Edit: November 07, 2016, 20:16:58 by Mike K »
Feb. 1971 Mercedes 280SL Auto  LHD (Last of W113 Series)
Aug. 1989 Mercedes R107 300SL RHD (Last of R107 Series)
http://michali.zenfolio.com
http://www.lebombo-safaris.com
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
It says: Vorsicht! Speed kills.
You have to check the alignment of engine, mounting block of the driveshaft and differential. I believe it cannot be done unless the car rests on all wheels - so you need a pit or a lift that supports the vehicle on it's tyres. It cautions that, if the engine is too high, it will damage the hood. (the engine support arms for the 280SE sedan position the engine 1/2 inch higher).
'69 280SL,Signal Red, 09 cam, License BB-59U
'67 230SL, 113042-10-017463 (sld)
'50 Jaguar Roadster XK120, #670.318 (sld)
tired engineer, West-Seattle,WA
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
I did the replacements as you note last year.  The forum has all the instructions.  I printed them out and followed them looking at the various parts and gathering the various tools necessary.  I have a mid-rise hoist and that helped get under the car.   It was a very simple job with the right tools.
Make sure you have the car placed far enough from a wall that you can get a good sized bar in there to lift the various parts.   I parked too close to a wall and could only use a small prybar (2') and even with my 250lbs kneeling on it there was just not enough leverage so I ended up having to borrow my daughter to help push.   The other side I used a 6' prybar and it was a simple operation.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
Mike K
    • Mike Kirkinis
TheEngineer & Ian thank you both for your feedback and input, very much appreciated.
Ian- good point about parking too close to a wall...
I've ordered the parts/mounts and have 3 or 4 free days towards the end of November when I plan to tackle these tasks.
Thanks and best,
Mike
Be advised that the sub-frame mounts can be seized in place and can require some effort to remove, possibly the use of heat.
Also, I have started only fitting genuine Mercedes engine mounts as I've had extremely premature failures of cheaper ones.
Mike K
    • Mike Kirkinis
Thanks Stick. I had already ordered the Febi/Bilstein sub frame mounts. I think I'll have to re order and get the MB mounts.
Mike
« Last Edit: November 08, 2016, 11:20:46 by Mike K »
Mike K
    • Mike Kirkinis
Picking upon Stick's comment regarding premature failures on non MB parts, I did some research and came across this thread, quite scary!
Wrong size bolts included in a MEYLE Sub frame bushing kit:
http://www.benzworld.org/forums/r-c107-sl-slc-class/1833586-sub-frame-bush-kit-problems-meyle.html
